It is currently Mon Aug 18, 2025 8:17 am
 Post subject: Neck Radius
PostPosted: Wed Apr 28, 2010 3:22 pm
Last Name: Charnock
Country: UK
Hi All
What would you say is the most common neck radius is of a steel string acoustic?
J
 Post subject: Re: Neck Radius
PostPosted: Wed Apr 28, 2010 4:38 pm
Last Name: Abercrombie
Do you mean fingerboard radius?
Something around 16" seems common, but really...whatever you want!
Pick a guitar you like and copy the fingerboard...
PostPosted: Wed Apr 28, 2010 4:44 pm
Last Name: Charnock
Country: UK
I checked Cumpiano's book and there is no mention of a specific radius, just take a sharp plane to it and plane !
Seems odd having nothing to work to
PostPosted: Wed Apr 28, 2010 4:55 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Martins are 16" (maybe not all of them????, but most of them)
Taylors are 15"
Gibsons are 12" (maybe not all of them?????)
Larrivee's are a compound radius that's pretty flat 15" at the nut, 21" at the other end (????)
PostPosted: Wed Apr 28, 2010 5:12 pm
You definitely should make a 'template' of some kind, or use a ''radius sanding block' to make sure you don't leave the middle flat and the edges rounded off too much.
That's a common (and easy) mistake and causes lots of grief when the fret ends won't seat properly.
Steve Senseney has posted some handy radius gauges in a .pdf file over at MIMF:
http://www.mimf.com/library/senseny_radiusgauges.pdf
Users browsing this forum: zmp2 and 15 guests
